Smart Distance Pro v2.1.7Požadavky: Android 2.0+
Popis: Smart Distance Pro is the extended set of Smart Tools collection (distance, golf-rangefinder, speed).
This range-finder(telemeter) measures the Distance to a target by the camera perspective.
The effective distance is 10m-1km.
To measure the distance, you should know the height(width) of a target.
Don't worry!! Man's height is 1.7m(5.6ft), a golf flag is 7ft, a bus is 3.2m(10.5ft), a door is 2.1m(7ft).
With that, we can guess the height(width) of almost everything.
If you know the airplane model, you can measure the distance from the sky.
For reference, Boeing 747's width is 72 meters.
Usage is simple. Input the height of the target, and touch the screen.
If the target is aligned by 2 lines, get the measured distance.
* Now, 3 tools for distance were completed.
1) Smart Ruler (Short, by touch) : 1-50cm
2) Smart Measure (Medium, trigonometry) : 1-50m
3) Smart Distance (Long, perspective) : 10m-1km
What's in this version:Updated: Feb. 1, 2013
v2.1.7 : More models are calibrated.
v2.1.6 : nmile, knot units added.
v2.1.3 : Enable Zoom by volume button.
v2.1.0 : Camera Zoom support.
Další info: Download: Mirror:
