Právě je ned 20.05.18 14:53
 Action Launcher Pro
Poděkovali mu: 4139 x
Příspěvek Action Launcher Pro
Action Launcher Pro v1.2.0
Požadavky: Android 4.0+
Obrázek Obrázek Obrázek Obrázek
Action Launcher re-imagines the concept of an Android launcher.
Put simply, Action Launcher is designed to get you where you need to go, faster.
It looks and feels like a natural launching pad for the Android ecosystem.
Features:
Sliding app drawer for instant access to all your apps
'Covers', a powerful new way to quickly launch apps and shortcuts without compromising the look of your carefully crafted homescreen.
Action bar present on the home screen
Highly organized customization options
Strong Play Store integration
Action Launcher automatically imports your existing launcher layout, so you'll instantly feel right at home.
What's in this version:
Updated : Feb. 1, 2013
NEW: Quicksearch - filter the apps, contacts and even music on your device, directly from the action bar's search button.
NEW: Covers can now be opened by swiping vertically on the cover icon.
NEW: Vastly improved the animation when opening the app drawer.
NEW: Allow configuration of the number of rows and columns on a homescreen page.
NEW: Vastly improved ICS widget support
NEW: WAY more features than Google will let me list here.
Naposledy upravil Germanicus dne ned 05.05.13 15:42, celkově upraveno 1
ned 03.02.13 09:30
Příspěvek Re: Action Launcher Pro [SDK 21]
Action Launcher v2.1.4 + Pro Key v2.0.0
Požadavky: ROOT Android 4.0.3 - 5.0, Modded Google Play
Updated: Oct. 18, 2014
v2.1.4
Fix importing from Google Now Launcher.
v2.1.3
Fix bug where search bar would display over top of Quickpage.
Bug fixes.
v2.1.2
Unread Count bug fixes.
v2.1
Initial Unread Count support.
"Ok, Google" voice activation. Requires Android 4.4 or later.
Add an option for the "Lock device" shortcut to opt for activation via double or triple tap.
Enhanced Icon scale options.
Option to enable Roboto Condensed.
Option to disable drawing of Cover/Shutter indicators.
ned 19.10.14 20:02
Action Launcher 2: Pro v2.2.1
Požadavky: ROOT Android 4.0.3 - 5.0, LP/MGP
Updated: Mar. 18, 2015
Stability fix when app loads.
ned 22.03.15 17:22
Uživatelé procházející toto fórum: gabio, VLADEK.F a 16 návštevníků
