Právě je pon 22.01.18 07:38
 Volume Control + (Persist +)
Poděkovali mu: 4125 x
Příspěvek Volume Control + (Persist +)
Persist + ( Volume Control ) v3.1.9
Požadavky: Android 2.1+
Persist puts you in complete control of your audio with a variety of volume controls and settings.
FEATURES
Create scheduled presets to easily apply your favourite settings.
Lock each volume level to prevent accidental changes.
Easily access volume controls and presets via notification shortcuts.
Switch the ringer mode between silent, vibrate, and normal.
Control vibrate modes (on, off, vibrate when silent) for ringer and notification.
Separate or link ringer and notification volume (android 2.3 and below).
Perform various notifications such as a vibrate or sound when the volume is locked.
View and change a variety of volume levels.
• Alarm
• Bluetooth
• Media
• Notification
• Ringer
• System
• Voice (in-call)
Fully interactive home-screen widgets
• 1x1 Preset - apply a set of audio settings
• 1x1 Preset list - easily apply any preset
• 1x1 Volume locker - change or lock volume levels
• 1x1 Vibrate - switch vibrate settings for ringer and notification
• 1x1 Ringer mode - change the ringer mode
• 4x1 Dashboard – a slew of interactive volume widgets
Flexible presets
Apply your favourite audio settings in one tap.
Quickly silence volume levels at an appointment, or at night for a comfortable sleep.
Presets can be scheduled to automatically apply at any time or location.
Volume locker
It's the best way to prevent volume changes when bumped in your pocket, avoiding unexpected bursts of sound or missed calls.
Using the “pocket locker” feature, you can automatically prevent accidental changes by locking the volume when your screen is off.
Fully interactive widgets
A wealth of features at your fingertips.
In an instant, you can change volume levels, apply presets, and much more, directly from your home-screen.
Updated: Mar. 24, 2013
- The volume % indicator (shown briefly next to the volume bar) is back
- bug fixes
Naposledy upravil Germanicus dne pát 18.07.14 10:39, celkově upraveno 3
úte 26.03.13 10:36
Příspěvek Re: Volume Control + (Persist +) [SDK 21]
Volume Control + v4.13
Požadavky: Android 4.0 - 5.0
Updated: Dec. 19, 2015
- Renamed the app from Persist+ to Volume Control+
- Fixed an issue with the scheduling of multiday time schedules.
ned 20.12.15 23:56
Volume Control + v4.22
Updated: Apr. 2, 2016
v4.22
Fixed Hong Kong and Singapore Chinese translations.
v4.21
Added a dark theme
Fixed several layout issues for pre lollipop devices
Fixed an issue that would cause the volume and preset notifications to sometimes appear in reverse order
Rearranged and renamed a few application settings for clarity.
ned 03.04.16 21:01
Uživatelé procházející toto fórum: Žádní registrovaní uživatelé a 17 návštevníků
