Právě je čtv 21.06.18 17:02
 iNoty
Poděkovali mu: 4151 x
Příspěvek iNoty
iNoty v1.0.1
Požadavky: Android 2.3+
Obrázek Obrázek Obrázek Obrázek
iPhone style status bar replacement with iOS 7 style. It is best when used with iLauncher.
Calendar is only supported on Android >= 4.0.
Tablet is not supported.
Consequent swipe down after the status bar pulled down will show the original status bar.
This may be useful to access the original status bar's system controls.
(Accessibility service should be enabled to use this feature.)
- Now automatically remove confirmed notifications.
- Network connection detection improved.
- Fixed a bug that notification message showed up in fullscreen mode.
- Now sliding animation of notification message works on Gingerbread.
ned 18.08.13 20:26
Příspěvek Re: iNoty [SDK 21]
iNoty v1.2.3.1
Požadavky: Android 2.3 - 5.0
Updated: Feb. 24, 2015
v1.2.3.1
- Trivial fixes
v1.2.3
- Updated the layout of Today tab.
- Calendar is loaded lazily so that battery consumption can be reduced.
- Fixed some touch issues.
pon 02.03.15 22:49
iNoty v1.3.0.1
Updated: Mar. 15, 2015
v1.3.0.1
- Fixed a crash on Android 4.2-
v1.3.0
- Ongoing notification is displayed in 'today' tab. (Only supported on Android 4.3+)
sob 21.03.15 22:21
Poděkovali mu: 37 x
Příspěvek Re: iNoty
What's New in Version 1.5.2.2
Reduced system status bar overlay problem - Notification center can be turned off so that only status bar can be used. This might not work correctly on some devices.
Nový google play link!
Youtube Channel:
úte 31.05.16 18:56
Uživatelé procházející toto fórum: dagdag, Google [Bot] a 11 návštevníků
