Právě je stř 23.05.18 19:46
 Unit Converter Pro
Poděkovali mu: 4141 x
Příspěvek Unit Converter Pro
Unit Converter Pro v2.0.0
Požadavky: Android 2.1+
Obrázek Obrázek Obrázek
Unit converter is a tool in the extended set of the Smart Tools collection.
There are already a lot of unit conversion apps on the market.
However, most are inconvenient and difficult to use because of a poor and complicated UI.
This Unit converter app is most intuitive and simple with a beautiful
and optimized UI that is designed for the casual user like you.
It goes without saying that you would not be able to find a better one.
Supported Units list
- Basic : length (distance), area, weight (mass), volume
- Life : temperature, time, speed, fuel consumption
- Science : pressure, force, work (energy), power
- Misc. : angle, data
Updated: Dec. 29, 2013
packet, deg.min.sec
čtv 02.01.14 13:59
Příspěvek Re: Unit Converter Pro
Unit Converter Pro v2.2.3
Požadavky: Android 2.2+
Updated: Sep. 18, 2015
AWG, minor fix
sob 19.09.15 17:42
Příspěvek Re: Unit Converter Pro [SDK 21]
Unit Converter Pro v2.3.0
Požadavky: Android 2.3 - 5.0
Updated: Dec. 15, 2015
v2.3.0:
ASCII, GEL, NIO
v2.3:
Material design, BTC, inch(Frac)
úte 15.12.15 22:55
Uživatelé procházející toto fórum: milann70 a 13 návštevníků
