Právě je ned 17.12.17 13:08
 RawVision
Poděkovali mu: 4123 x
Příspěvek RawVision
RawVision v1.5.4
Požadavky: Android 2.2+
RawVision is the most complete solution for your photographic workflow, in between the camera and the computer.
Transfer, organize, sort, rate, categorize, play, pixel-peep, edit, share to social networks
RawVision lets you do all that and more in a ludic yet powerful way. You will not go to the computer anymore.
This application is especially intended for Android tablets, but it will work very well with smartphones too.
Features:
- RawVision supports Nikon NEF, Canon .CR2 , SONY .ARW, Pentax .PEF and .DNG and Samsung .SRW files, Olympus .ORF, Panasonic RW2, Fujifilm's .RAF.
- opens only thumbnails for Leica M DNG and Nikon D100 Nef files
- JPEG and PNG
- preview of .MOV files(Android>3.0)
- Transfer from: camera usb connection(MTP/PTP), usb external reader, Eye-Fi and advanced local browsing
- Bookmark your favorite locations
- Gallery display. Select a file with a click. To perform batch actions, select all the files and press the action button on the bottom-right of the screen.
- Select a rating and category in full Ssreen to help sort photos. Import to LightRoom with the XMP sidecar files.
You can also define your own category labels.
- FullScreen view
You can browse all the photos by sweeping the screen right or left. There are invisible areas on the left and right to quickly change photo.
Zoom on photos with a pinch.
Delete a photo right away
start a slideshow
Check the histogram and Exifs
Toggle the actions bar with a single tap, double tap to have the photo fit to screen
- Image editor
Edit and process your photos with the embbeded editor.
Compatible with Aviary filters.
- Import Files
You can import selected files by choosing a root folder, then a name for the new import folder - or the current date. You can also choose to rename the files and delete them after import.
Import also works directly from your camera via USB.
- Delete files
You can delete files either one a time or several in a batch by selecting them before.
- JPEG extraction
Extract a JPEG preview of the RAW files with resize and auto-rotate options.
You can extract several files in a batch.
- Share Files - "Open with..."
"Share" your files with other apps on your Android device.
Sketch an extracted preview, launch a video file, share by facebook, twitter, send by email, store on dropbox etc...
- Rename files
- Eye-Fi support
Eye-Fi needs a little configuration.
You should be able to use AP mode if you registered your device wihtin the card.(With the official app for example) - but Not tested yet
Otherwise the direct mode works great.
First connect the device to the WiFi AP (Ey-fi card in direct mode) with the wpa2 key in the Eye-Fi Center desktop app.
Then in RawVision, enter the uploadKey - please google how to get it.
Choose the destination folder and start the service.
Photos will then appear as they are sent from the camera.
Note: you cannot use Eye-Fi service while another eyefi app is running.
Updated: July 7, 2014
new: navigation is now in a drawer on the left
úte 15.07.14 14:02
Příspěvek Re: RawVision [SDK 21]
RawVision v1.6.1
Požadavky: Android 4.0 - 5.0
Updated: Sep. 6, 2015
v1.6.1:
fix: crash on saving for some Android 4.0.3 devices
fix: add tag icon showing on mtp images.
v1.6.0:
new: image editor has been updated. No longer the 3mp output limit !
new: jpeg extract: exifs are being correctly exported to jpegs
new: write access error: the app hints to the proper folder of the external disk where you can store your files.
fix: bug when editing jpeg from the action bar
fix: metadata and histogram in fullscreen would not appear
sob 09.01.16 02:00
RawVision v1.6.11
Požadavky: Android 4.1+
Updated: Sep. 17, 2016
1.6.11:
new: usb photos can now be filtered by type. This is usefull if you shoot RAW+JPEG and don't require a double check.
This also helps battery life and display speed (choose jpg rather than raw, because they are quicker to transfer.
1.6.9-1.6.10:
minor issues
1.6.8:
Permissions
new: support for Android M permissions
fix: minor issues
1.6.7:
Chromecast compatibility
pon 02.01.17 13:35
Uživatelé procházející toto fórum: Sogou [Bot] a 12 návštevníků
