Právě je sob 25.03.17 08:37
 RTSP Player Pro
Poděkovali mu: 4116 x
Příspěvek RTSP Player Pro
RTSP Player Pro v4.3.1
Požadavky: Android 4.0+
RTSP Player Pro is a very simple, fast application to playback network stream from IP cameras, video servers
and surveillance system with unlimited Stream Record function.
Key features:
Supported types of streaming: HTTP-HLS, RTSP, RTP, UDP (Multicast stream support), RTMP, MMS
Hardware decoder using hardware acceleration with processor optimization – high speed rendering for modern platform
Multi-core decoding provides the dual-core device’s performance
Easy streams list control – add, delete and modify your streams
Preview video while browsing in file list
Smooth playback of FLV files, you do not need to install the Flash Player plug-in
Thumbnails for live streams
Replay for live HLS stream
Digital zoom and picture shifting
Download and playback M3U list
Simplest search of video file
Record a stream
Ad free
Updated: Dec. 30, 2014
Added RECORDING for live stream and CUTTING into pieces for files
Added Android 5.0 support
Added sliding menu
Added selectable control for audio volume, brightness and playback speed
Fixed issue with skip load thumbnail if there is only one file in folder
Added settings for recording : quota, duration, video only and other
Added localization for following languages: French, German, Spanish,Portuguese, Korean, Chinese
Fixed some bugs issued on latest version
čtv 01.01.15 18:06
Příspěvek Re: RTSP Player Pro
RTSP Player Pro v4.4.0
Updated: Dec. 24, 2015
Recorded files are compatible with most social network and media application
Added the support of Android Marshmallow
Added the support for arm64-v8a
Improved video engine
Fixed bugs in last version
pon 11.01.16 15:07
Uživatelé procházející toto fórum: Bing [Bot], krtek47 a 11 návštevníků
