Právě je pon 28.05.18 08:51
 Everywhere Clipboard Pro
Poděkovali mu: 4149 x
Příspěvek Everywhere Clipboard Pro
Everywhere Clipboard Pro v1.2.2
Požadavky: Android 1.5+
Everywhere Clipboard extends Android clipboard function
and brings real desktop clipboard experience to you on mobile phone.
Imagine a clipboard panel that you can quickly locate, copy, paste,
and delete from clipboard history without leaving your current window.
Unlike other clipboard apps found in Android Market, Everywhere Clipboard quick panel can be used
anywhere in any window instantly and can be hidden at any time too
and that makes it superior than any other existing solution. It also reads txt file for copy and paste action too!
If you are a heavy email or note taking user, you will find Everywhere Clipboard increase your productivity to next level.
Thanks to its desktop like clipboard solution.
Features:
Instant on, always available clipboard panel
Manage content to copy from files/folders
Built in note editor for quick file creation
Easy to use folder management
Supports both clipboard history based or file based copy
More to come
Added features in PRO
Unlocked clipboard history limit
Able to create multiple folder for text file management
Ads removal
Updated: Feb. 27, 2013
Add support to non standard screen dimension
sob 14.03.15 22:37
Uživatelé procházející toto fórum: Bing [Bot] a 13 návštevníků
