Právě je ned 20.05.18 20:38
 Qcktag - temporary contacts
Poděkovali mu: 4140 x
Příspěvek Qcktag - temporary contacts
Qcktag Pro - temporary contacts v1.5
Požadavky: Android 2.2 - 5.0
Qcktag Caller ID - known tags are shown when receiving/making calls!
Every time you complete a call from/to an unknown number,
Qcktag will ask you for a quick tag you can attach to the phone number.
Tagged numbers are not sent to the contact list, but are accessible through the main Qcktag application.
Works for both incoming and outgoing calls
Works for incoming SMS too!
Option for either a notification or a popup asking for the tag
‘Tag Later’ - option to save all numbers as untagged and you can tag them later
Qcktag Caller ID - For tagged numbers, if you receive/make calls to them, the tag will be displayed when call is initiated or received.
Option to tag all numbers or only unknown numbers
Add tags manually, from existing contact or from call history!
If adding from existing contact, option is available to remove from contact list.
Quickly search for tags
Quickly call or message a tagged number. You can also share tags and add tags as calendar events
Option to add to contacts if you eventually find out it is a number worth keeping
Android Wear support! Now tag your phone calls with voice from your Android Wear watch
Backup and restore tags and preferences
Updated: Nov. 19, 2014
1. Some material design love!
2. Option to auto remove notification after specified time
3. Share a tag
4. Add tag as a calendar event
5. Sort tags
6. Better looking caller ID
ned 03.05.15 09:47
Uživatelé procházející toto fórum: gabio, Google [Bot] a 18 návštevníků
