Právě je ned 27.05.18 20:46
 ROEHSOFT DRIVE-EXPERT
Poděkovali mu: 4149 x
Příspěvek ROEHSOFT DRIVE-EXPERT
ROEHSOFT DRIVE-EXPERT v1.09
Požadavky: ROOT Android 2.0+
Manage,repair and modify Tool for Android SD/HD/FLASH Drives.
Save Time for Power Users
You can Create Partitions on all external Drives. And Check and repair the internal NAND and eMMC ext4
and vfat drives.
For all Operations on Android you need Kernel Filesystem Support.
Updated: Feb. 9, 2015
Better ROOT detection
ned 28.06.15 22:19
Poděkovali mu: 3133 x
Požadavky: Android 2.0 a vyšší + ROOT
Popis: Manage,repair and modify Tool for Android SD/HD/FLASH Drives.
Screen:
Stahuj zde: Patched:
Save Time for Power Users. This App is not for Beginners or normal User! You can Create Partitions on all external Drives. And Check and repair the internal NAND and eMMC ext4 and vfat drives.For all Operations on Android you need Kernel Filesystem Support.It can create a Firmware Dump (and scripts) easy for postprocessing on a PC (Linux) wich is needed to edit Drivelayout for the internal eMMC Drives. You can also repair this internal eMMC or NAND Drives but be very careful!When you have a Business you may use it for fastrepair internal drives or any other service.
This App is nothing for Beginners!!! For Expert and Profi User wich know what is to do. It can save Recovery,System,Cache,Boot Images and on some MTD devices alos direct dump the kernel.img and logo.bin.
Before you change anything on internal Drives please create a Firmware Backup!!!
THX není povinnost,THX je slušnost ...
Naposledy upravil MONT! dne ned 28.06.15 22:47, celkově upraveno 1
Duplicita, stejná verze...sloučeno!
ned 28.06.15 22:47
Příspěvek Re: ROEHSOFT DRIVE-EXPERT [SDK 21]
ROEHSOFT DRIVE-EXPERT v1.11
Požadavky: ROOT Android 2.0 - 5.0
Updated: July 10, 2015
v1.11
Automount Error output added for users which forget to set system rw settings
v1.10
Kingoroot users, now it is working!
Download Patched apk:
Download Original apk:
úte 21.07.15 14:24
Uživatelé procházející toto fórum: assue, matus55 a 10 návštevníků
