Právě je čtv 24.01.19 14:09
 Sky Map pro Android
Poděkovali mu: 3524 x
Příspěvek Sky Map pro Android
Sky Map v1.8.5
Požadavky: Android: 4.0.3 a vyšší
Popis: Google Sky Map turns your Android-powered mobile phone into a window on the night sky.
Screen:
Obrázek Obrázek Obrázek
Sky Map is a hand-held planetarium for your Android device. Use it to identify stars, planets, nebulae and more.
Originally developed as Google Sky Map, it has now been donated and open sourced.
pon 13.06.16 00:31
Příspěvek Re: Sky Map pro Android
Sky Map v1.8.6b
Co je nového:
• Make the calibration dialogs less frequent
• Chinese translation fix
• Added Epsilon Lyrae (by request)
• New: no need to accept EULA with each update from now on
• Minor stability fixes
pon 13.06.16 21:48
Sky Map v1.9.0
Co je nového:
Now uses your phone's gyroscope (if your phone has one) for a smoother experience. Enable it from settings.
Greek translations (thanks: ftsamis)
Fixed Russian translations (thanks: AlexLitvino)
pon 11.07.16 11:02
Sky Map v1.9.1c
Požadavky: Android: 4.0 a vyšší
Co je nového: Work around for bugs in the Samsung S4 and Note 3 that caused crash on start up.
Uses gyro by default if supported
ned 25.09.16 17:03
Uživatelé procházející toto fórum: Žádní registrovaní uživatelé a 10 návštevníků
