Právě je čtv 21.06.18 17:03
 Pixoff: Battery Saver PRO
Poděkovali mu: 3170 x
Příspěvek Pixoff: Battery Saver PRO
Pixoff: Battery Saver PRO v2.2
Požadavky: Android: 4.4 a vyšší
Popis: Saves battery by applying a filter that turns off pixels of AMOLED screens.
Screen:
Obrázek Obrázek Obrázek
Saves battery by applying a filter that turns off pixels of AMOLED screens, also incorporates the possibility of make a filter night decreasing so damaging blue light and you can further reduce battery consumption with facility to put a wallpaper to true black.
AMOLED screens doesn't have a backlight at all. Instead, each little sub-pixel is like a tiny red, blue, or green colored light. If the screen is instructed to display black, it doesn't need to block any light, it simply doesn't light up any of the little colored sub-pixels.
THX není povinnost,THX je slušnost ...
stř 15.06.16 03:16
Příspěvek Re: Pixoff: Battery Saver PRO
Pixoff: Battery Saver PRO v3.1.0
Co je nového: Black pixels save you a lot of power because those pixels can be turned completely off. There is a relationship between brightness and power, but to really save juice you need a true black.
stř 22.06.16 03:13
Pixoff: Battery Saver PRO v4.0.0
Co je nového:
Greater battery savings.Improve speed UI.
úte 16.08.16 02:50
Uživatelé procházející toto fórum: Google [Bot] a 9 návštevníků
