Právě je sob 21.04.18 08:37
 Smartloq Math
Poděkovali mu: 3069 x
Příspěvek Smartloq Math
Smartloq Math v1.3
Požadavky: Android: 4.0.3 a vyšší
Smartloq Math je první z nové řady chytrých aplikací, jejichž cílem je rozvíjení znalostí stálé po celý den - okysličování mozkovny :'D :-@
Screen:
Obrázek Obrázek Obrázek
When it comes to our education we all want to do our best; and in order to do our best we must practice the material we've learned to create lasting knowledge of it. However, with our busy schedules, demanding course loads, and competing priorities, finding time for review can sometimes be challenging.
Improve your math skills with practice:
• Apply Smartloq Math to your Games, Social Media, or any apps you choose
• Select which operations to focus on (addition, subtraction, multiplication or division)
• Select a range of X and Y values from 0 to 100
• Set the number of attempts (Smartloq will show you the answer and let you pass after you reach the maximum)
• Check your statistics and review your history in the log
Smartloq was conceived from a student’s perspective to aid with the learning process. Smartloq functions like a security lock, but instead of requiring a PIN, Smartloq presents a single question when you launch any paired apps. This keeps you practicing and learning throughout the day as you use your smartphone or tablet. When answering a question, either you are correct and the original app will launch, or you are asked to try again. After reaching the maximum number of attempts Smartloq will show you the correct answer and let you through. Smartloq does not block you from getting to your favorite apps.For Parents - Smartloq has the option to set a security PIN for access to the main app allowing you to manage and lock the settings.Smartloq also has statistics and a full history log. This provides valuable feedback for discovering any problem areas that need attention, or if it’s time to increase/decrease the level of difficulty.
THX není povinnost,THX je slušnost ...
pon 25.07.16 11:40
Uživatelé procházející toto fórum: Žádní registrovaní uživatelé a 13 návštevníků
