Právě je čtv 06.05.21 22:44
 [Ad-free] Mobizen : Screen Recorder
Poděkovali mu: 4167 x
Příspěvek [Ad-free] Mobizen : Screen Recorder
Mobizen : Screen Recorder v3.1.1.70
Požadavky: liší se dle zařízení
Download the most easy to use screen recorder Mobizen now and create your first, amazing video! Mobizen is the most easy-to-use, convenient screen recorder that allows you to record, capture and edit.
Screen:
Obrázek Obrázek Obrázek
How to Make the Perfect First Video?
ㆍClear Screen Recording in FULL HD!
※ Highest Quality supplied ▷ 1080P Resolution, 12.0Mbps Quality, 60 FPS
ㆍCapture your reactions freely while recording game sound and your voice with Facecam!
ㆍYou can record long videos without worrying while saving onExternal Memory (SD Card)!
ㆍ(Trim, Cut, Images, etc.) Raise the quality of your video with a Variety of Video Editing Features!
ㆍPut in your favorite BGM and an Intro & Outro Video to make a personalized video!
ㆍRecord a clean screen Without a Watermark with Clean Recording Mode!
Available Only with Mobizen
ㆍAnyone can use it with No rooting starting from OS 4.4!
ㆍUse Screen Recording, Capture, and Editing all for FREE!
ㆍYou can Remove the Watermark for FREE!
Naposledy upravil milann70 dne sob 22.04.17 02:36, celkově upraveno 2
ned 05.03.17 09:26
Příspěvek Re: [Ad-free] Mobizen : Screen Recorder for Samsung
Mobizen Screen Recorder v3.2.1.14
Požadavky: Android: 4.4 a vyšší
Co je nového:
*Fixed Critical Crash Issues with Certain Devices
: In some cases, we found Mobizen crashing while recording. We will continue to improve Mobizen!
Stahuj zde: Paid content unlocked
sob 22.04.17 02:35
Příspěvek Re: [Ad-free] Mobizen Screen Recorder
Mobizen Screen Recorder v3.5.1.10 [Premium]
Co je nového:
1. Added support to 2K resolution for recording!
2. Fixed an issue when application crashes by using a special character in the recorded video’s file name.
pát 24.08.18 01:50
