Požadavky: Android 2.0+
This is an issue for Theme Concept key lime pie HD 7 in 1 all Launcher .
Also compatible with Apex Launcher, Nova Launcher, ADW, Holo and others.
This topic contains 400 icons and adding every week!
And also contains wallpapers in high resolution.
for users of go launcher also contains skins for widgets go
Recommended system according to your android.
Go Launcher from Gingerbread to the current
Noba Launcher from Android 4.0 to the current
ADW from android 1.6 to the current
HOLO Launcher works from android 2.3 with a style "Holo" as the current andrid the most recommended
for best effect on older phones.
Updated: Feb. 20, 2013
Initial release
Kód: Vybrat vše
https://play.google.com/store/apps/details?id=com.go.launcherex.kelylime.ics.theme
Kód: Vybrat vše
http://www22.zippyshare.com/v/54122430/file.html
Kód: Vybrat vše
http://www.embedupload.com/?d=1RDNJPGBAC
http://directmirror.com/files/IW1FFW5W
http://uloz.to/xgSK1Gh/concept-key-lime-pie-hd-7-in-1-v1-0-apk
