Požadavky: Android 4.0+
Bold and unique this custom icon set is sure to catch the eye, with over 400+ custom icons using a white base,
chrome accent and unique gradients to fill out the icon they have an overall great appearance.
What Do You Get:
440+ Custom icons
6 Wallpapers on a cloud based server that can be updated at any time without app updates
7 Docks to be used with the launchers that support
Custom Folder backgrounds
Easy to use app that houses all of this material
Supported Launchers:
Nova
Action
Apex
Adw/AdwEX
Atom
Next
Smart
Solo
Tsf
Other launchers may work they just arent officially supported
Updated: Jan. 21, 2014
- 20 new icons
- fixed icon search feature
- fixes and additions in app filter
Kód: Vybrat vše
https://play.google.com/store/apps/details?id=jatx2wne.launchertheme.blesd
Kód: Vybrat vše
http://www53.zippyshare.com/v/55898435/file.html
Kód: Vybrat vše
http://www.tusfiles.net/e0luqh89t957
http://uloz.to/xUQkLG51/blesd-launcher-theme-v1-2-apk
http://ulozto.sk/x5PZFLKs/blesd-launcher-theme-v1-2-apk
