Právě je čtv 24.05.18 18:47
 New Star Trek Live Wallpaper 1
Poděkovali mu: 4141 x
Příspěvek New Star Trek Live Wallpaper 1
New Star Trek Live Wallpaper 1 v1
Požadavky: Android 2.1+
I created this video to use as a live wallpaper to go with my New Star Trek Themes.
Unfortunately I am more of a graphics person than a java expert.
This app should run on most devices, but it's buggy and depending on your device turns the video to look low resolution.
The video is 1920x1080 HD resolution with a high bitrate. If the app is unacceptable to you as is,
the following is a tutorial of how to extract the video from the app to be used with 'Video Live Wallpaper'
whose app will let you set my video as live wallpaper in a way that is far superior.
They simply outclass this app in every way.
If you are using Android 4.1 and up, this won't work.
Jelly Bean ROOTED users:
Just use Titanium Backup to backup this app, then restore (app only not data) and it works.
In my explanation I will be using 'ES File Explorer (cupcake)'
After installing my app, open ES File Explorer
press
->'Manager' -> 'App Manager'
press
->'Types' -> 'All'
Scroll to find this app and long press till the menu appears.
Select 'Backup' and then hit the back button till you return to the root of your storage/SD card.
Open folder 'backups' -> 'apps'
Find this app and long press till the menu appears.
Select 'Extract to' -> 'Current path'
Open folder 'assets' -> 'video' There it is! Now just long press and select 'cut'.
Go back to the root of storage or a preferred folder and paste it there where you can find it
when selecting your 'Video source' in Video Live Wallpaper'.
Video Live Wallpaper is free with in app ads only in it's menu (No push notifications). They also run on donations
pon 30.09.13 13:11
