Právě je ned 20.05.18 19:07
 Spring Trees Live Wallpaper
Poděkovali mu: 4139 x
Příspěvek Spring Trees Live Wallpaper
Spring Trees Live Wallpaper v2.01
Požadavky: Android 2.1+
Spring flowering trees that gently sway while petals fly in the air carried by the wind.
Clouds and the sun move over the sky that shifts color dynamically according to the time of day.
As the night slowly falls the moon appears clearer and clearer until fully visible at midnight.
The day starts with a dazzling sunrise around 6 am by the lower left corner
and ends with a magnificent sunset in the other corner around 6 pm.
The full version is highly customizable:
- select background (rape field, mount fuji or meadow)
- select foreground flowers
- select flower count
- select tree (pink sakura, white cherry tree or magnolia)
- set tree size
- set ground level
- set number of petals
- set petal size
- set any time of day (colors and light change)
- or use dynamic real time mode
- set sunrise time
- set sunset time
- option to use GPS once a day to determine location and automatically calculate sunrise and sunset times,
in order to make the sun move similar to the real sun in your location
- change wind speed
- set star count
- set night sky brightness
- set night light intensity
- set position and size of the moon
- set rotation speed of the sun
- show/hide the sun
- show/hide high clouds
- show/hide low clouds
- toggle silhouette mode
- use true color (24 bit)
Updated: Mar. 6, 2014
Option to use GPS once a day to determine location and automatically calculate sunrise and sunset times,
pát 11.04.14 15:11
