Stránka 1 z 1 [ Příspěvek: 1 ]
blacked out // blakZent ★
čtv 31.03.16 21:44 Příspěvek
blacked out // blakZent ★ v135
Požadavky: Android 5.0 - 6.0
Welcome to the first and original dark UI available for the CyanogenMod 12 Theme Engine.
This theme is perfect for those on AMOLED displays, energy efficient and is also a stylistic preference.
ATTENTION:
If you're on MM6.0 with CMTE (CM13, DU) AND you dirty flash,
MAKE SURE YOU REVERT STOCK THEME BEFORE YOU UPDATE.
Or you SHOULD expect at most THREE soft reboots before your phone works again!
This is due to dirty flash theme recompiles that get corrupt (CM side).
Updated: Mar. 30, 2016
- Add RR Icons
- Inverted Instagram, Twitter, Dropbox
- Bug fixes to all Google Apps
- Chrome dialogs now visible
- Fix Textra Transparent Heads Up
- Fix FC for Google+, Google Photos
