Stránka 1 z 1 [ Příspěvek: 1 ]
Notch Battery bar Live wallpaper
ned 23.09.18 06:56 Příspěvek
Notch Battery bar Live wallpaper v3.3 [Paid]
Požadavky: Android: 7.0 a vyšší
Popis: Supported Devices:
* Huawei P20 range
* OnePlus 6
Screen:
Obrázek Obrázek Obrázek
Please do not install on other devices
Please try the trial version before buying
Use the notch as a battery bar in your P20 with this live wallpaper.
Pick an image of your choice and add the battery bar to it with custom colors.
Will work on all devices but there is no point if you do not have a notch, so P20 pro is also an option but it is not tested on P20 pro.
